This guide will show you how to correctly replace the Disk Drive.
Unscrew the two 9 mm Phillips #1screws holding the battery in place.
Grab the battery and pull it away from the laptop to remove it.
Unscrew the 10 9.0 mm screws holding the back panel on using a Phillips head #1 screwdriver.
Insert a metal spudger tool in the seam between the back cover and the laptop itself. Gently run the spudger around the edge to pop the cover off.
Pry up the back panel from the rest of the laptop using a spudger.
Unscrew one 3.0 mm screw from the disk drive using a #1 Phillips screwdriver.
Grab the disk drive with one hand and the laptop with another, then gently pull the disk drive straight toward yourself.
