Toshiba Satellite C55-C5240 Motherboard Replacement
  1. Toshiba Satellite C55-C5240 Motherboard Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite C55-C5240 Motherboard Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite C55-C5240 Motherboard Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Make sure you turn off the laptop before starting.
    • Remove the two 6.5mm PH1 Phillips screws securing the battery.
  2. Toshiba Satellite C55-C5240 Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite C55-C5240 Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite C55-C5240 Motherboard Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the battery out, keeping it flat and parallel to the laptop so that it slides out easily.
  3. Toshiba Satellite C55-C5240 Motherboard Replacement, Back cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite C55-C5240 Motherboard Replacement, Back cover: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the ten 6.5mm PH1 Phillips head screws that hold down the back cover.
  4. Toshiba Satellite C55-C5240 Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite C55-C5240 Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite C55-C5240 Motherboard Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the plastic opening tools, open the back cover and remove it from the laptop.
    • It is recommended that you start from a corner and run the tool along the edge of the cover.
    • Be careful not to bend or crack the cover.
  5. Toshiba Satellite C55-C5240 Motherboard Replacement, Hard Drive: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite C55-C5240 Motherboard Replacement, Hard Drive: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite C55-C5240 Motherboard Replacement, Hard Drive: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The hard drive is on the bottom left side.
    • Remove both releases from the rubber hard drive mount.
  6. Toshiba Satellite C55-C5240 Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite C55-C5240 Motherboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite C55-C5240 Motherboard Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the hard drive from underneath on the right side.
    • While holding it up, pull it away from its connector so that it disconnects.
  7. Toshiba Satellite C55-C5240 Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite C55-C5240 Motherboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite C55-C5240 Motherboard Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel off the rubber hard drive mount.
  8. Toshiba Satellite C55-C5240 Motherboard Replacement, Motherboard: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite C55-C5240 Motherboard Replacement, Motherboard: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite C55-C5240 Motherboard Replacement, Motherboard: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the disk drive to the right and gently lift up the disk out the laptop.
  9. Toshiba Satellite C55-C5240 Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite C55-C5240 Motherboard Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite C55-C5240 Motherboard Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the 5 ribbon cables.
    • To remove, unlock the latch of each ribbon and pull it out.
  10. Toshiba Satellite C55-C5240 Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite C55-C5240 Motherboard Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • There is a wifi card underneath the large ribbon cable on the right.
    • Remove the plastic piece that covers the screw.
  11. Toshiba Satellite C55-C5240 Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite C55-C5240 Motherboard Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the PH1 Phillips head 3.0 mm long screw holding it in.
    • Pull out the WiFi card.
  12. Toshiba Satellite C55-C5240 Motherboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite C55-C5240 Motherboard Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite C55-C5240 Motherboard Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the 4 regular cables.
    • Carefully pull the cable parallel to the board, not up or at an angle.
  13. Toshiba Satellite C55-C5240 Motherboard Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite C55-C5240 Motherboard Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the seven PH1 Phillips head 3.0 mm long screws that hold the motherboard in place.
  14. Toshiba Satellite C55-C5240 Motherboard Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite C55-C5240 Motherboard Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite C55-C5240 Motherboard Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully lift the motherboard from the edges.
Abdel Feliciano Gonzalez
crwdns2935283:002/28/17crwdne2935283:0
722 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S1-G5, Nance Spring 2017 crwdns2935289:0USF Tampa, Team S1-G5, Nance Spring 2017crwdne2935289:0
USFT-NANCE-S17S1G5
crwdns2935297:018crwdne2935297:0
crwdns2936753:030crwdne2936753:0 47
crwdns2942667:0crwdne2942667:0 7,926
