This is a guide that will assist you with replacing your RAM in a Toshiba Satellite C55-C5240.
Remove the two 6.5mm PH1 Phillips screws securing the battery.
Pull the battery out, keeping it flat and parallel to the laptop so that it slides out easily.
Unscrew the ten 6.5mm PH1 Phillips head screws that hold down the back cover.
Using the plastic opening tools, open the back cover and remove it from the laptop.
The RAM is at the upper middle area of the motherboard.
Push down on the clips on either side of the RAM stick evenly.
