Toshiba Satellite C55-A5302 ODD Replacement
  1. Toshiba Satellite C55-A5302 ODD Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Power down the laptop and remove all power cords. After this is done, turn the laptop over.
  2. Toshiba Satellite C55-A5302 ODD Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the battery latches outwards away from the center of the device.
    • The right latch will slide to the right, and left latch to the left.
  3. Toshiba Satellite C55-A5302 ODD Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift and remove the battery from the device.
  4. Toshiba Satellite C55-A5302 ODD Replacement, Hard Drive: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the Phillips #1 screwdriver to unscrew the thirteen screws on the back of your device.
  5. Toshiba Satellite C55-A5302 ODD Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the middle plastic cover to expose the hard drive.
  6. Toshiba Satellite C55-A5302 ODD Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the Phillips #1 screwdriver, remove the two screws holding the hard drive in place.
  7. Toshiba Satellite C55-A5302 ODD Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three screws using the Phillips #1 screwdriver.
    • Insert you fingers into the rubber ends and gently pull the hard drive out of the device.
  8. Toshiba Satellite C55-A5302 ODD Replacement, Optical Disk Drive: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the Phillips #1 screwdriver to remove the two screws under the hard drive.
  9. Toshiba Satellite C55-A5302 ODD Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a metal spudger and run it along the edges of the computer to take off the plastic back cover. (Starting near a port usually allows more space for the spudger to be inserted)
  10. Toshiba Satellite C55-A5302 ODD Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slowly work from one end to the other to lift the back cover off.
  11. Toshiba Satellite C55-A5302 ODD Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite C55-A5302 ODD Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab hold of the optical drive and elevate it slightly and remove it from the computer.
Nicole Hague
crwdns2935283:004/10/18crwdne2935283:0
620 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team S2-G2, Ramos Spring 2018 crwdns2935289:0Eastern Washington University, Team S2-G2, Ramos Spring 2018crwdne2935289:0
EWU-RAMOS-S18S2G2
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 557
