Toshiba Satellite C55-A5286 Hard Drive Replacement
  1. Toshiba Satellite C55-A5286 Hard Drive Replacement, Hard Drive: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the AC adapter and all other auxiliary components from the laptop.
  2. Toshiba Satellite C55-A5286 Hard Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • There is a removable panel on the underside of the laptop with one 5-mm screw holding it in place.
    • Use the screwdriver to remove the screw and then remove the back panel.
  3. Toshiba Satellite C55-A5286 Hard Drive Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Underneath this panel is a silver square with rubber around the edges. This is the hard drive. On the side of the hard drive nearest to the manufacturer’s label, there is a large, flat 8-mm screw that is holding the hard drive in place.
    • Use the screwdriver to remove the screw.
  4. Toshiba Satellite C55-A5286 Hard Drive Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully hold the sides of the hard drive with the rubber and pull the hard drive out. It should remove fairly easily.
Nicole Zellers
crwdns2935283:011/06/18crwdne2935283:0
265 crwdns2915208:0crwdne2915208:0
IUPUI, Team S1-G5, Hovde Fall 2018 crwdns2935289:0IUPUI, Team S1-G5, Hovde Fall 2018crwdne2935289:0
IUPUI-HOVDE-F18S1G5
The hard drive is ‘encased’ in a foil-looking, very flexible ‘enclosure’.
On the screw-side (near the label), each corner of the foil enclosure has a rubber black stuffed between the drive and the laptop - these blocks are connected to the enclosure via a rubber ‘string’. If you pull those nubs straight up, you can pull on them towards the label to disengage the drive from its SATA interface.
William Totman - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 1,184
