Toshiba Satellite C55-A5140 CD Drive Replacement
  1. Toshiba Satellite C55-A5140 CD Drive Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure the device is unplugged, completely off, and not warm to the touch.
    • Check for any visible battery defects such as bulges, bends or cracking as they could be signs of a leaking or deformed battery.
    • Do not handle a deformed battery. Deformed batteries can cause burns and exposure to harmful chemicals.
    • Flip device over and locate two switches on the back of the device.
  2. Toshiba Satellite C55-A5140 CD Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite C55-A5140 CD Drive Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide switch 1 towards the unlock symbol on the device (switch should click into place).
    • Slide switch 2 towards the unlocked symbol on the device.
    • While holding switch 2 in the unlocked position, use the notch located at the top of the battery to pull battery out and away from the device.
    • Switch 2 does not lock into place and will need to be held in unlocked position.
  3. Toshiba Satellite C55-A5140 CD Drive Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull battery free from device and release switch 2.
  4. Toshiba Satellite C55-A5140 CD Drive Replacement, CD Drive: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure that the device is unplugged, completely off, and that the device is not warm to the touch.
    • Flip the device over so you see the bottom, and loosen the 5mm PH#1 screw on the L shaped access panel.
    • The screw will not come out of access panel, simply unscrew until loose.
  5. Toshiba Satellite C55-A5140 CD Drive Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the plastic opening tool to open access panel by sliding it into notch near screw and prying access panel(L-shaped) away from device.
    • Pull panel completely free from device and set aside.
  6. Toshiba Satellite C55-A5140 CD Drive Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the 2mm PH#1 screw next to the Toshiba Device information tag.
  7. Toshiba Satellite C55-A5140 CD Drive Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite C55-A5140 CD Drive Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite C55-A5140 CD Drive Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the plastic opening tool, pry the CD drive up.
    • Once the CD drive is partially separated from the device, grasp with your hand and slide it out of the slot.
Cameron Chapman
crwdns2935283:009/27/17crwdne2935283:0
533 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team S1-G5, Carnegie Fall 2017 crwdns2935289:0Eastern Washington University, Team S1-G5, Carnegie Fall 2017crwdne2935289:0
EWU-CARNEGIE-F17S1G5
crwdns2942667:0crwdne2942667:0 566
