In this guide, you will learn how to replace the RAM in your computer, using a screwdriver and a plastic opening tool.
Click button 1 to the unlocked position.
Push and hold button 2 to the left.
As you push button 2 to the left position, simultaneously lift up the battery pack.
Using the Phillips #1 screwdriver, remove the eleven 2.5mm screws.
Remove the one 2.5mm Phillips #1 middle plate screw.
Lift up the middle vent panel.
Set the panel to the side.
Using the plastic opening tool, remove the outer panel and set to the side.
Using your fingers, unclip the two side clips.
The RAM should now be at a 30 degree angle.
Using your fingers, unclip the top two clips.
The RAM should just pop out. You can remove it with your fingers.
