This guide details how to replace the optical drive in your laptop. You will need a pry tool and Phillips screwdriver to complete the prerequisite steps (removing the back of the device) to access the optical drive, remove it, and replace it with a new one.
Click button 1 to the unlocked position.
Push and hold button 2 to the left.
As you push button 2 to the left position, simultaneously lift up the battery pack.
Using the Phillips #1 screwdriver, remove the eleven 2.5mm screws.
Remove the one 2.5mm Phillips #1 middle plate screw.
Lift up the middle vent panel.
Set the panel to the side.
Using the plastic opening tool, remove the outer panel and set to the side.
Locate the opticaldrive and find where it is slotted into the motherboard.
Gently lift up the optical drive at a slight angle, and pull it towards you to remove it.
This is an awful guide - it does not tell you that there are another 6 or more screws under the keyboard - this is bad.
