Removing the bottom lower case of your Toshiba Satellite device will allow you to access its inner components, such as the RAM. This will be useful for most repairs.
Click button 1 to the unlocked position.
Push and hold button 2 to the left.
As you push button 2 to the left position, simultaneously lift up the battery pack.
Using the Phillips #1 screwdriver, remove the eleven 2.5mm screws.
Remove the one 2.5mm Phillips #1 middle plate screw.
Lift up the middle vent panel.
Set the panel to the side.
Using the plastic opening tool, remove the outer panel and set to the side.
