Toshiba Satellite A65-S126 Internal Fan Replacement
  1. Toshiba Satellite A65-S126 Internal Fan Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the laptop over so the bottom is facing up.
    • Slide each of the three tabs on the bottom half of the assembly into the unlocked position.
  2. Toshiba Satellite A65-S126 Internal Fan Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift the battery out of the computer.
  3. Toshiba Satellite A65-S126 Internal Fan Replacement, Upper Assembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the single 3mm Phillips #00 screw that secures the wireless card cover.
  4. Toshiba Satellite A65-S126 Internal Fan Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the WIFI module cover. It will pull right off.
  5. Toshiba Satellite A65-S126 Internal Fan Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite A65-S126 Internal Fan Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the white and black wires from the WiFi module.
  6. Toshiba Satellite A65-S126 Internal Fan Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the twelve 8mm button head Phillips #00 B8 screws.
    • Remove the two 14 mm button head Phillips #00 B14 screws.
    • Remove the two 10 mm Phillips #00 battery compartment screws.
    • Remove the two 8 mm Phillips #00 screws.
  7. Toshiba Satellite A65-S126 Internal Fan Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the seven 4mm flat Phillips #00 screws.
    • Remove the seven 20mm button head Phillips #00 screws.
  8. Toshiba Satellite A65-S126 Internal Fan Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the plastic opening tool to pry the two halves apart.
  9. Toshiba Satellite A65-S126 Internal Fan Replacement, Internal Fan: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 2 mm Phillips #00 screws that secure the fan to the motherboard.
  10. Toshiba Satellite A65-S126 Internal Fan Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the small plug connecting the fan power cable to the motherboard.
    • Carefully lift the fan out of the computer.
Cole Uhland
crwdns2935283:009/30/13crwdne2935283:0
216 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 14-8, Forte Fall 2013 crwdns2935289:0Cal Poly, Team 14-8, Forte Fall 2013crwdne2935289:0
CPSU-FORTE-F13S14G8
crwdns2942667:0crwdne2942667:0 1,170
