Turn off the computer.
Disconnect the charging cable from computer.
Flip the computer upside down.
Slide latches labeled #1 and #2, located outside the battery cover, away from each other.
Gently lift and pull the battery out of the device.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use tweezers to remove rubber screw covers on 4 corners of frame around screen.
Use flat side of spudger to pry the top and sides of the frame around screen.
Turn device onto its screen side to access the bottom of hinge portion of the screen and push bottom piece of frame along device hinge until it loosens.
Return device to upright position and gently pull frame away from screen.
Remove 2 Phillips 5.6 mm screws from below screen.
Unplug pink and white monitor cable from bottom of screen.
Remove 3 Phillips 3.2 mm screws from each side of the metal case around screen.
Pull the screen forward from the top out of the metal frame enough to see the back of the screen.
Hold the screen with one hand and gently remove the display cable from the back side of the screen.
