Toshiba Satellite A215-S7425 RAM Replacement
  1. Toshiba Satellite A215-S7425 RAM Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn off the computer.
    • Disconnect the charging cable from computer.
    • Failure to unplug the cable could result in electric shock.
    • Flip the computer upside down.
  2. Toshiba Satellite A215-S7425 RAM Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide latches labeled #1 and #2, located outside the battery cover, away from each other.
    • Latch #1 will click over and stay while latch #2 will have to be held for battery to release.
  3. Toshiba Satellite A215-S7425 RAM Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift and pull the battery out of the device.
  4. Toshiba Satellite A215-S7425 RAM Replacement, RAM: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the RAM vented plastic cover in the center of the device.
  5. Toshiba Satellite A215-S7425 RAM Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite A215-S7425 RAM Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Loosen 1 Phillips 4.2 mm size captive screw and lift cover off device to expose 2 RAM sticks.
  6. Toshiba Satellite A215-S7425 RAM Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite A215-S7425 RAM Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite A215-S7425 RAM Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Anti-Static Wrist Strap
    $7.95
    • Locate 2 metal pinchers on either side of the 1st RAM stick.
    • Use a finger from each hand to push the 2 pinchers simultaneously away from the stick of RAM and towards the exterior of the case.
    • The RAM stick will automatically rise up. Gently pull out the RAM stick with one hand.
    • The use of a anti-static wrist strap while working with the RAM is advise to prevent electrostatic discharge(ESD) from damaging the RAM.
  7. Toshiba Satellite A215-S7425 RAM Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite A215-S7425 RAM Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite A215-S7425 RAM Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To remove the 2nd RAM stick, repeat previous steps.
    • You will be unable to remove 2nd RAM stick if the first one is not removed first.
Marianne
crwdns2935283:009/08/14crwdne2935283:0
647 crwdns2915208:0crwdne2915208:0
Pasco Hernando, Team 5-2, Prince Fall 2014 crwdns2935289:0Pasco Hernando, Team 5-2, Prince Fall 2014crwdne2935289:0
PHSC-PRINCE-F14S5G2
crwdns2931471:010crwdne2931471:0
crwdns2935297:018crwdne2935297:0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 403
