Toshiba Satellite A215-S7425 Keyboard Replacement
  1. Toshiba Satellite A215-S7425 Keyboard Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn off the computer.
    • Disconnect the charging cable from computer.
    • Failure to unplug the cable could result in electric shock.
    • Flip the computer upside down.
  2. Toshiba Satellite A215-S7425 Keyboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide latches labeled #1 and #2, located outside the battery cover, away from each other.
    • Latch #1 will click over and stay while latch #2 will have to be held for battery to release.
  3. Toshiba Satellite A215-S7425 Keyboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift and pull the battery out of the device.
  4. Toshiba Satellite A215-S7425 Keyboard Replacement, Keyboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the device so the top side is facing up. Open device to expose key board.
  5. Toshiba Satellite A215-S7425 Keyboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate plastic bezel above keyboard and use flat side of spudger to pry away from device.
  6. Toshiba Satellite A215-S7425 Keyboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove 2 Phillips 3.1 mm size screws from each side above the keyboard.
  7. Toshiba Satellite A215-S7425 Keyboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift keyboard a few inches above device, exposing the attached ribbon cable.
  8. Toshiba Satellite A215-S7425 Keyboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently disconnect the ribbon cable from the motherboard, it should easily slide out from the connector.
    • To avoid damage to the ribbon cable, Do not yank or forcibly remove. To avoid further damage to the cable do not bend it. A bent ribbon cable may cause the keyboard to not function correctly.
Marianne
crwdns2935283:009/08/14crwdne2935283:0
647 crwdns2915208:0crwdne2915208:0
Pasco Hernando, Team 5-2, Prince Fall 2014 crwdns2935289:0Pasco Hernando, Team 5-2, Prince Fall 2014crwdne2935289:0
PHSC-PRINCE-F14S5G2
crwdns2931471:010crwdne2931471:0
crwdns2935297:018crwdne2935297:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 580
