Toshiba Satellite A215-S7425 Hard Drive Replacement
  1. Toshiba Satellite A215-S7425 Hard Drive Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn off the computer.
    • Disconnect the charging cable from computer.
    • Failure to unplug the cable could result in electric shock.
    • Flip the computer upside down.
  2. Toshiba Satellite A215-S7425 Hard Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide latches labeled #1 and #2, located outside the battery cover, away from each other.
    • Latch #1 will click over and stay while latch #2 will have to be held for battery to release.
  3. Toshiba Satellite A215-S7425 Hard Drive Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift and pull the battery out of the device.
  4. Toshiba Satellite A215-S7425 Hard Drive Replacement, Hard Drive: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite A215-S7425 Hard Drive Replacement, Hard Drive: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate hard drive cover opposite the battery on the lower left corner of the device.
    • Loosen 2 Phillips 4.2 mm size captive screws from cover.
    • Lift cover slightly from the edge where the screws are and pull slowly out and to the right, releasing it from its latches on the left.
  5. Toshiba Satellite A215-S7425 Hard Drive Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite A215-S7425 Hard Drive Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite A215-S7425 Hard Drive Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Anti-Static Wrist Strap
    $7.95
    • Locate the thin plastic tab folded on right side of hard drive case.
    • Hold plastic tab and gently pull tab slightly up and to the left to remove hard drive case from device.
    • To avoid damage to the hard drive or motherboard connectors; Do not pull plastic tab in a straight up direction.
    • The use of a anti-static wrist strap while working with the hard drive is advise to prevent electrostatic discharge(ESD) from damaging the hard drive.
  6. Toshiba Satellite A215-S7425 Hard Drive Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove 4 (2 on each side) Phillips 4.1 mm size screws from case.
  7. Toshiba Satellite A215-S7425 Hard Drive Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide case away from hard drive.
Marianne
crwdns2935283:009/08/14crwdne2935283:0
647 crwdns2915208:0crwdne2915208:0
Pasco Hernando, Team 5-2, Prince Fall 2014 crwdns2935289:0Pasco Hernando, Team 5-2, Prince Fall 2014crwdne2935289:0
PHSC-PRINCE-F14S5G2
crwdns2931471:010crwdne2931471:0
crwdns2935297:018crwdne2935297:0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 1,030
