Turn off the computer.
Disconnect the charging cable from computer.
Flip the computer upside down.
Slide latches labeled #1 and #2, located outside the battery cover, away from each other.
Gently lift and pull the battery out of the device.
Locate hard drive cover opposite the battery on the lower left corner of the device.
Loosen 2 Phillips 4.2 mm size captive screws from cover.
Lift cover slightly from the edge where the screws are and pull slowly out and to the right, releasing it from its latches on the left.
crwdns2935267:0crwdne2935267:0Anti-Static Wrist Strap$7.95
Locate the thin plastic tab folded on right side of hard drive case.
Hold plastic tab and gently pull tab slightly up and to the left to remove hard drive case from device.
Remove 4 (2 on each side) Phillips 4.1 mm size screws from case.
