This guide will show you how to remove or replace the battery of the Toshiba Satellite A210 laptop. No tools are necessary for this procedure.
Slide the battery lock tab away from the center of the laptop to unlock the battery.
Slide the battery release tab away from the center of the laptop and hold it.
Lifting from the small notch between the two tabs, pull the battery out of the laptop.
