If your CDs or DVDs are not running correctly or at all on your computer, then it is either due to the disc drive being dirty, loose parts and/or broken. This guide will show the user how to safely remove the disc drive.
Turn your laptop upside down, and slide the right release tab outward.
Using you left hand, hold the left release tab towards the left side and then pull the battery out.
Loosen the screw located on the cover of the RAM using Phillips #1 screwdriver.
With your fingers, carefully remove the middle panel by lifting the edge with the indent.
Remove the 4.0 mm screw above the small metal tab with a Phillips 00 screwdriver.
Push down on the metal tab under the cover with the plastic opening tool and push the disc drive partially out.
Grab the drive and pull it out of the laptop.
