Upgrading the RAM is a straightforward process that can significantly improve performance.
Two RAM slots allow up to 512MB of PC1600 DDR SDRAM.
The RAM access panel is located near the middle of the bottom.
Unscrew the single screw labeled F4 on the panel.
Using a spudger, inserted into the notch under the screw hole, pry open and remove the cover.
Pull outward on each pair of restraining clips to free each chip.
The RAM chips can now be pulled out.
