Replacing or upgrading the hard drive is a simple procedure that results in improved storage and functionality.
The hard drive is located on the front left of your laptop.
Unscrew the single small screw labeled F4 located on the right side of the panel.
Insert a spudger into the indent near the screw to pry open and remove the cover.
Use a spudger to disconnect the hard drive by shifting the entire drive to the right.
Lift the hard drive up and out of the laptop.
