Toshiba SD-K740 Front Flap Tray Door Replacement
  1. Toshiba SD-K740 Front Flap Tray Door Replacement, Top Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the DVD player before beginning.
    • Remove the three 7.7 mm screws from the back panel using a Phillips #0 screwdriver.
  2. Toshiba SD-K740 Front Flap Tray Door Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba SD-K740 Front Flap Tray Door Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the DVD player on its side.
    • Remove the 7.7 mm screw.
    • Flip the DVD player onto its other side.
  3. Toshiba SD-K740 Front Flap Tray Door Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the DVD player over onto its front face.
    • Remove the back panel by lifting up and pulling it towards yourself.
  4. Toshiba SD-K740 Front Flap Tray Door Replacement, Front Panel: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the DVD player so its top is sitting on your working surface.
    • Lift and push away the two tabs located in the middle of the player.
    • The front panel will not detach during this step, so do not force it.
  5. Toshiba SD-K740 Front Flap Tray Door Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the DVD player on its side.
    • Lift and slide forward the single tab on the side.
  6. Toshiba SD-K740 Front Flap Tray Door Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba SD-K740 Front Flap Tray Door Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grasp the front panel and pull forward to your right to remove it.
  7. Toshiba SD-K740 Front Flap Tray Door Replacement, Front Flap Tray Door: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba SD-K740 Front Flap Tray Door Replacement, Front Flap Tray Door: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • On back side of front panel very carefully apply pressure to the left hand side of the flap hinge.
    • There is just enough tolerance in the plastic to allow removal, be careful of brittle plastic.
  8. Toshiba SD-K740 Front Flap Tray Door Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the peg is free from the left restraint, carefully remove the left part of the flap.
    • Carefully remove the right peg from the restraint.
    • Do not pull away from the front panel because the spring is still attached.
    • Do not force the plastic.
  9. Toshiba SD-K740 Front Flap Tray Door Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the spring from the end of the right peg by pulling the door away from the spring.
    • Do not pull away from the front panel until the spring has been removed from the flap.
John Lokker
crwdns2935283:001/20/11crwdne2935283:0
324 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 1-16, Amido Winter 2011 crwdns2935289:0Cal Poly, Team 1-16, Amido Winter 2011crwdne2935289:0
CPSU-AMIDO-W11S1G16
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 1,510
