Toshiba Qosmio X775-3DV80 Wi-Fi Chip Replacement
  1. Toshiba Qosmio X775-3DV80 Wi-Fi Chip Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Qosmio X775-3DV80 Wi-Fi Chip Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn your laptop over so the underside is facing up.
  2. Toshiba Qosmio X775-3DV80 Wi-Fi Chip Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Qosmio X775-3DV80 Wi-Fi Chip Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Identify the two sliding locks on either side of the battery.
    • Simultaneously slide both locks outward to release the battery.
  3. Toshiba Qosmio X775-3DV80 Wi-Fi Chip Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the battery straight out of its slot to remove it.
  4. Toshiba Qosmio X775-3DV80 Wi-Fi Chip Replacement, Optical Drive: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the optical drive retaining screw on the underside of the laptop.
  5. Toshiba Qosmio X775-3DV80 Wi-Fi Chip Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips #00 screwdriver, remove the optical drive retaining screw.
  6. Toshiba Qosmio X775-3DV80 Wi-Fi Chip Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Qosmio X775-3DV80 Wi-Fi Chip Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using your finger or a spudger, push the optical drive out of its compartment so you can grab it.
    • Pull the optical drive out of its slot in the side of the laptop.
  7. Toshiba Qosmio X775-3DV80 Wi-Fi Chip Replacement, RAM: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Loosen the single screw on the service panel by twisting counterclockwise with a Phillips #00 screwdriver.
    • It is a captive screw that will remain attached to the service panel.
  8. Toshiba Qosmio X775-3DV80 Wi-Fi Chip Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a spudger or plastic opening tool, pry off the service panel.
  9. Toshiba Qosmio X775-3DV80 Wi-Fi Chip Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Qosmio X775-3DV80 Wi-Fi Chip Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Qosmio X775-3DV80 Wi-Fi Chip Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using your fingers, pull the retaining clips away from the RAM sticks.
    • Pull the RAM sticks out of the slots.
  10. Toshiba Qosmio X775-3DV80 Wi-Fi Chip Replacement, Keyboard: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Qosmio X775-3DV80 Wi-Fi Chip Replacement, Keyboard: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #00 screwdriver, remove all the remaining fourteen screws from the bottom case of the laptop.
    • The service panel should already be removed.
  11. Toshiba Qosmio X775-3DV80 Wi-Fi Chip Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Qosmio X775-3DV80 Wi-Fi Chip Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #00 screwdriver, remove the five screws under the service panel.
    • Remove the retaining clip.
  12. Toshiba Qosmio X775-3DV80 Wi-Fi Chip Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a spudger, pry the keyboard from the top panel of the laptop.
    • Make sure to pry it off all around.
  13. Toshiba Qosmio X775-3DV80 Wi-Fi Chip Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Qosmio X775-3DV80 Wi-Fi Chip Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Qosmio X775-3DV80 Wi-Fi Chip Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the two ribbon cables connecting the keyboard to the laptop.
    • Unplug the connector on the bottom of the laptop.
  14. Toshiba Qosmio X775-3DV80 Wi-Fi Chip Replacement, Fan: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Separate the two halves of the base of the laptop.
  15. Toshiba Qosmio X775-3DV80 Wi-Fi Chip Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Qosmio X775-3DV80 Wi-Fi Chip Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the two cables.
  16. Toshiba Qosmio X775-3DV80 Wi-Fi Chip Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the palmrest assembly.
  17. Toshiba Qosmio X775-3DV80 Wi-Fi Chip Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Qosmio X775-3DV80 Wi-Fi Chip Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #00 screwdriver, remove the four screws securing the fan assembly to the laptop.
  18. Toshiba Qosmio X775-3DV80 Wi-Fi Chip Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Qosmio X775-3DV80 Wi-Fi Chip Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the fan-motherboard connector.
    • Remove the fan unit.
  19. Toshiba Qosmio X775-3DV80 Wi-Fi Chip Replacement, Wifi Chip: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Detach the two coaxial connections from the wifi chip.
  20. Toshiba Qosmio X775-3DV80 Wi-Fi Chip Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Qosmio X775-3DV80 Wi-Fi Chip Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #00 screwdriver, remove the two screws from the wifi chip.
  21. Toshiba Qosmio X775-3DV80 Wi-Fi Chip Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the wifi chip by pulling it out of the PCIe slot.
Jesse Adam Ory
crwdns2935283:003/24/19crwdne2935283:0
745 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S2-G1, Bailey Spring 2019 crwdns2935289:0UMass Dartmouth, Team S2-G1, Bailey Spring 2019crwdne2935289:0
UMASSD-BAILEY-S19S2G1
crwdns2935297:021crwdne2935297:0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 700
