If your disks run on other devices but not this laptop, use this guide to replace the CD Drive.
Flip the switch on the right to the unlocked position.
Hold the switch on the left and pull the battery up towards you, using the marked tab, to take it out.
Use a JIS #0 screwdriver to unscrew the two 4.6 mm screws at the base of the casing.
Pull off the part of the case that's now loose by the indicated tab.
Take out the 4.7mm long JIS #0 screw with a JIS Screwdriver.
The CD Drive is now loose. Pull it straight out of the side.
