Toshiba Portege Z835-P330 Battery Replacement
  1. Toshiba Portege Z835-P330 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the thirteen 1.4mm screws on back of device using a Phillips #2 screwdriver.
  2. Toshiba Portege Z835-P330 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate hidden screw found in the middle of back hardcover.
    • Found under rubber covering shown in picture.
    • Remove the single Torx Security screw using a TR7 screwdriver.
  3. Toshiba Portege Z835-P330 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Peel off hardcover to expose interior of device.
    • Force may be required but hardcover should detach smoothly.
  4. Toshiba Portege Z835-P330 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the six 1 mm screws using a Phillips #1 screwdriver.
  5. Toshiba Portege Z835-P330 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the white plug connected to the battery by gently pulling it out of the socket.
    • Plug should easily detach without force.
  6. Toshiba Portege Z835-P330 Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift battery up by its sides, and it should easily come off.
Dominic Whiting
crwdns2935283:002/08/18crwdne2935283:0
927 crwdns2915208:0crwdne2915208:0
University of North Texas, Team S2-G3, Thomas Spring 2018 crwdns2935289:0University of North Texas, Team S2-G3, Thomas Spring 2018crwdne2935289:0
UNT-THOMAS-S18S2G3
These steps also work for the Z935-P300. NOTE: the center screw in step two is a Torx Security TR7.
Jim Flattery - crwdns2934203:0crwdne2934203:0
Will it lose it’s memory when the power and battery are disconnected? Do I need to back it up before I do this? My battery is so dead that the laptop shuts down after just a few minutes without the ac cord plugged in.
Thank you!
pat_brady_pb@yahoo.com - crwdns2934203:0crwdne2934203:0
I suspect you have already completed your repair and now know the answer, however, in the event that you are still waiting on a response. The short answer is no, the storage drive will not loose data when changing the battery. Despite this, it is always wise to have a backup.
Jim Flattery -
Could anyone please tell me which type of screws are these ?
lourencopintodasilva - crwdns2934203:0crwdne2934203:0
Which screws are you referring to? I believe they all have their details size and type listed above. Is there one in particular you need further detail on?
Jim Flattery -
crwdns2942667:0crwdne2942667:0 4,919
