Toshiba Portege R705-P35 Wi-Fi Card Replacement
  1. Toshiba Portege R705-P35 Wi-Fi Card Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn off and unplug the laptop.
    • Failure to turn off and unplug the cable could result in electric shock.
    • Place the laptop upside-side-down with the hinges towards you.
  2. Toshiba Portege R705-P35 Wi-Fi Card Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your right hand to move the right switch from the locked position to the unlocked position.
    • Use your left hand to move the left switch from the locked position to the unlocked position.
  3. Toshiba Portege R705-P35 Wi-Fi Card Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Portege R705-P35 Wi-Fi Card Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • While keeping the left switch unlocked, pull the battery away from the computer with your right hand.
  4. Toshiba Portege R705-P35 Wi-Fi Card Replacement, RAM Plate: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Portege R705-P35 Wi-Fi Card Replacement, RAM Plate: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Portege R705-P35 Wi-Fi Card Replacement, RAM Plate: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Loosen the two captive screws in the plate with a Phillips #00 screwdriver.
    • Remove the plate from the laptop.
  5. Toshiba Portege R705-P35 Wi-Fi Card Replacement, Hard Drive Plate: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Loosen the two captive screws in the hard drive plate using a Phillips #00 screwdriver.
  6. Toshiba Portege R705-P35 Wi-Fi Card Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Portege R705-P35 Wi-Fi Card Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your hands to remove the hard drive plate from the laptop.
  7. Toshiba Portege R705-P35 Wi-Fi Card Replacement, Back Plate: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 13 mm screws from the back plate using a Phillips #0 screwdriver.
  8. Toshiba Portege R705-P35 Wi-Fi Card Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Portege R705-P35 Wi-Fi Card Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift and remove the small plate from the laptop.
  9. Toshiba Portege R705-P35 Wi-Fi Card Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the thirteen 6 mm screws from the back plate using a Phillips #00 screwdriver.
    • Remove the five 5 mm screws from the back plate using a Phillips #00 screwdriver.
  10. Toshiba Portege R705-P35 Wi-Fi Card Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Portege R705-P35 Wi-Fi Card Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the back plate off, starting from the right side, being cautious of the ports on the left side.
  11. Toshiba Portege R705-P35 Wi-Fi Card Replacement, Wi-Fi Card: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your fingers to disconnect the white and black cords from the Wi-Fi card.
  12. Toshiba Portege R705-P35 Wi-Fi Card Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 3 mm screws from the Wi-Fi card using a Phillips #00 screwdriver.
  13. Toshiba Portege R705-P35 Wi-Fi Card Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Portege R705-P35 Wi-Fi Card Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the Wi-Fi card out of the laptop at a 45° angle.
Kathryn Hockenbury
crwdns2935283:003/23/22crwdne2935283:0
833 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 1-4, Botvin Spring 2022 crwdns2935289:0UMass Dartmouth, Team 1-4, Botvin Spring 2022crwdne2935289:0
UMASSD-BOTVIN-S22S1G4
crwdns2942667:0crwdne2942667:0 310
