This guide will help Toshiba users replace or add RAM to their laptop devices.
Locate the battery on the backside of the laptop. The battery is usually located at the bottom.
Locate the battery lock button and push it towards the unlock position.
Hold the next lock in the unlock position. Simultaneously pull the battery towards you.
Using a Phillips #00 Screwdriver unscrew the 2 40mm screws that are located on the plate covering the RAM.
Pull the sides holding the RAM in place until there is a slight pop.
The RAM stick will lift up on its own. Simply remove it.
Place new RAM into the RAM drive and gently press until there is a slight pop.
To reassemble your device, simply follow steps 1-3 in reverse order.
