You may need to replace your laptop's battery if it is not holding a charge anymore, or not charging at all. To replace the battery on the Toshiba Portege laptop, no tools are necessary, just your own fingers!
Flip the laptop over. Keep the front end facing away from you, so the battery appears at the top.
Slide the locking mechanism to the right and hold.
While holding the locking mechanism to the right, insert your finger into the tab and lift up.
