Toshiba Portege M400 Touchpad Replacement
  1. Toshiba Portege M400 Touchpad Replacement, Keyboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the front face plate with a plastic opening tool.
    • Unscrew and remove the two 3.8mm screws labeled B3 with the #1 Phillips screwdriver.
  2. Toshiba Portege M400 Touchpad Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the keyboard toward you starting from the edge closest to the screen.
    • This ribbon still connects the taptor to the keyboard.
    • Gently place the keyboard on top of the track pad with the keys upside down.
  3. Toshiba Portege M400 Touchpad Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Portege M400 Touchpad Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Portege M400 Touchpad Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Find the white ribbon connector (where the keyboard is still attached to the rest of the laptop).
    • Remove the screw on the metal plate that keeps the ribbon from sliding out.
    • Gently remove the metal plate and set it aside.
  4. Toshiba Portege M400 Touchpad Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Portege M400 Touchpad Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Dislodge the white ribbon connector from the two clips holding it in place using the plastic opening tools.
    • Pull out the white ribbon connector with your fingers.
  5. Toshiba Portege M400 Touchpad Replacement, Touchpad: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Portege M400 Touchpad Replacement, Touchpad: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a plastic opening tool to carefully remove the cover of the touchpad.
    • Remove the one 1/2" inch screw on the backside of the laptop.
  6. Toshiba Portege M400 Touchpad Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Portege M400 Touchpad Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull up the touch-pad piece and lay it upside down.
    • The touch-pad will still be connected to the computer.
  7. Toshiba Portege M400 Touchpad Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Portege M400 Touchpad Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull back the tab to disconnect the touchpad to the laptop.
Varsha Roopreddy
crwdns2935283:004/19/13crwdne2935283:0
37 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 4-17, Maness Spring 2013 crwdns2935289:0Cal Poly, Team 4-17, Maness Spring 2013crwdne2935289:0
CPSU-MANESS-S13S4G17
crwdns2942667:0crwdne2942667:0 1,279
