Toshiba Portable DVD Player SD-P1700 DVD Drive Replacement
  1. Toshiba Portable DVD Player SD-P1700 DVD Drive Replacement, DVD Drive: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Portable DVD Player SD-P1700 DVD Drive Replacement, DVD Drive: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the DVD player upside down.
    • Slide the lock switch to the side.
    • Slide the battery pack toward the lock switch and off of the back case.
  2. Toshiba Portable DVD Player SD-P1700 DVD Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the following twelve screws:
    • Ten 7 mm Phillips #00 screws
    • Two 8 mm Phillips #00 screws
  3. Toshiba Portable DVD Player SD-P1700 DVD Drive Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your fingers to pull the back case away from the body of the DVD player.
    • Remove the back case.
  4. Toshiba Portable DVD Player SD-P1700 DVD Drive Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your fingers to pull off the plastic sheet.
  5. Toshiba Portable DVD Player SD-P1700 DVD Drive Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the following screw:
    • One 2 mm Phillips #00 screw
    • Detach the gray wire.
  6. Toshiba Portable DVD Player SD-P1700 DVD Drive Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the ribbon cable by pulling it straight out of the connector.
  7. Toshiba Portable DVD Player SD-P1700 DVD Drive Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the following five screws:
    • Three 4 mm Phillips #00 screws
    • Two 2 mm Phillips #00 screws
  8. Toshiba Portable DVD Player SD-P1700 DVD Drive Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove three rubber stoppers.
  9. Toshiba Portable DVD Player SD-P1700 DVD Drive Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the following screws:
    • Two 4mm Phillips #00 screws
  10. Toshiba Portable DVD Player SD-P1700 DVD Drive Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your fingers to pry the motherboard away from the upper case so you can access the DVD drive wires.
  11. Toshiba Portable DVD Player SD-P1700 DVD Drive Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the DVD player over to access the drive wires.
    • Pull the bundled cable away from the connector in the same direction the individual wires are running.
  12. Toshiba Portable DVD Player SD-P1700 DVD Drive Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove all of the DVD drive components from the case.
Katarina Howald
crwdns2935283:003/18/20crwdne2935283:0
205 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 447
