Toshiba NB205 N330PK Speaker Removal
  1. Toshiba NB205 N330PK Speaker Removal, Power Button: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba NB205 N330PK Speaker Removal, Power Button: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Start by first removing the battery.
    • Move the first release switch to the right position.
    • Move the second release switch to the right position while pulling the battery towards the top of the netbook.
  2. Toshiba NB205 N330PK Speaker Removal: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba NB205 N330PK Speaker Removal: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the bit driver and a Phillips #0 bit, remove the three circled screws, 5 mm in length.
    • Using the bit driver and a Phillips #0 Bit, remove the two circled screws labelled F6. (These hold the keyboard) one screw may be under a rubber stopper
  3. Toshiba NB205 N330PK Speaker Removal: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba NB205 N330PK Speaker Removal: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • While holding the top of the netbook, flip the netbook over.
  4. Toshiba NB205 N330PK Speaker Removal: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba NB205 N330PK Speaker Removal: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully lift off the power bar assembly for access to the button and receiver.
  5. Toshiba NB205 N330PK Speaker Removal, Speaker: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba NB205 N330PK Speaker Removal, Speaker: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba NB205 N330PK Speaker Removal, Speaker: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the spudger to gently pry around the seam of the keyboard. This will release the keyboard assembly from the body.
  6. Toshiba NB205 N330PK Speaker Removal: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba NB205 N330PK Speaker Removal: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Reach under the keyboard and disconnect the electrical connection.
    • Lift the keyboard assembly out and away from the netbook.
  7. Toshiba NB205 N330PK Speaker Removal: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba NB205 N330PK Speaker Removal: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two noted screws, 5 mm in length, with a bit driver and Phillips 3/16" tool.
  8. Toshiba NB205 N330PK Speaker Removal: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba NB205 N330PK Speaker Removal: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the cable away from the connector in the same direction as the individual wires using your hands or tweezers.
    • Pull evenly on the full width of the cable so that no individual wires are overly strained.
    • Use a spudger to gently pry the bezel from retaining clips.
    • This will allow the keyboard bezel to lift off of the body.
  9. Toshiba NB205 N330PK Speaker Removal: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the pointed tip of a spudger to carefully push on each side of the speaker connector to release it. Alternating from one side to the other, gently “walk” the connector out of its socket.
    • Always pull cables by their connectors and not the wires themselves.
  10. Toshiba NB205 N330PK Speaker Removal: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba NB205 N330PK Speaker Removal: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use Phillips #0 screwdriver to remove the two retaining screws on the speaker assembly.
    • Lift out the old speaker assembly.
Mason McCaskill
crwdns2935283:010/18/13crwdne2935283:0
1 021 crwdns2915208:0crwdne2915208:0
Clemson, Team 14-2, Benson Fall 2013 crwdns2935289:0Clemson, Team 14-2, Benson Fall 2013crwdne2935289:0
CLEM-BENSON-F13S14G2
crwdns2935297:027crwdne2935297:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 726
