This guide will show you how to replace the screen on your Toshiba Excite 7c. There are no commercially available parts as of publication, but one could be scavenged from a tablet that has a different issue.
Place an iFixit opening tool in the seam between the screen and back casing.
Apply pressure down all four sides to separate the back casing from the screen.
Place the tablet face down and carefully remove the back panel.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use a Phillips screwdriver to remove the five 6 mm screws from the motherboard.
Use tweezers to gently disconnect the two ribbon cables.
Pull straight up to remove the board.
