Toshiba Excite 7c Antenna Replacement
  1. Toshiba Excite 7c Antenna Replacement, Antenna: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Excite 7c Antenna Replacement, Antenna: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To open your device use the plastic opener. Locate the seam on your device and gently separate applying pressure down all four sides.
    • The back casing will start to peel away from the screen.
  2. Toshiba Excite 7c Antenna Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Excite 7c Antenna Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Excite 7c Antenna Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • You can locate the antenna underneath the motherboard as seen here.
    • You do not need to remove the motherboard!
    • There are two tabs located on the side of the antenna. You will need to release these tabs by slightly and gently pushing the tabs away from the antenna card.
    • Pull the card out with your tweezers and replace with new antenna.
Reyna Serrato
crwdns2935283:010/25/14crwdne2935283:0
96 crwdns2915208:0crwdne2915208:0
Gateway, Team 1-2, Johnson Fall 2014 crwdns2935289:0Gateway, Team 1-2, Johnson Fall 2014crwdne2935289:0
GCC-JOHNSON-F14S1G2
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 195
