Toshiba Encore Mini Speakers Replacement
  1. Toshiba Encore Mini Speakers Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Encore Mini Speakers Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To replace the battery, the rear cover must first be removed.
    • Using the flat end of the spudger, gently pry open the back case from the rest of the device.
    • It may be easier to start along one of the long edges and carefully work your way toward the corner, then along the short edge.
  2. Toshiba Encore Mini Speakers Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the rear cover and set it aside.
  3. Toshiba Encore Mini Speakers Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove the electrical tape that holds the battery in place.
  4. Toshiba Encore Mini Speakers Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Encore Mini Speakers Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using needle-nose tweezers, gently push the large white wire connector (connected to the black, red and blue wires) out of its housing.
  5. Toshiba Encore Mini Speakers Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift the battery out of the device.
    • Be careful not to pull on the connecting wires.
  6. Toshiba Encore Mini Speakers Replacement, Speakers: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the spudger to pull the speaker wire plug from its socket.
  7. Toshiba Encore Mini Speakers Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully use the metal spudger to remove the speaker from the frame of the phone.
    • The speaker is attached with some double-sided adhesive and may be difficult to remove.
Khaled Alsaghayer
crwdns2935283:003/04/17crwdne2935283:0
IUPUI, Team S5-G5, Wilson Spring 2017 crwdns2935289:0IUPUI, Team S5-G5, Wilson Spring 2017crwdne2935289:0
IUPUI-WILSON-S17S5G5
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 178
