crwdns2959928:0crwdne2959928:0 ↓This replacement guide will walk you through the steps needed to replace the battery on your Toshiba Encore Mini and will serve as the first step for any other replacements you may need to perform. Prior to removing any parts on your device, backing-up all data and photos to an external storage device is recommended. In this guide, you will be removing the following:
- Back Cover
- Battery
Using the flat end of the spudger, gently pry open the back case from the rest of the device.
Remove the rear cover and set it aside.
Carefully remove the electrical tape that holds the battery in place.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Using needle-nose tweezers, gently push the large white wire connector (connected to the black, red and blue wires) out of its housing.
Gently lift the battery out of the device.
crwdns2935229:05crwdne2935229:0
Be sure to remove any SD cards you have first.
ecw0647 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
But where do i buy the battery?
sissyhana - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
