This guide will show users how to replace the memory (RAM) from the Toshiba Dynabook.
Push apart the two spring loaded plastic tabs labeled #1 and #2.
The battery is now easily removed by pulling up from the notched tab on the inside edge.
Remove the 4.5 mm screw labeled 4 and lift up panel from the vented 2" x "4 memory cover in the middle of the computer.
Gently pull apart the two metal support clips on either side of the chip to release from the socket. It will spring upwards when it is properly released.
Gently pull the chip out of the clips.
