Toshiba Chromebook 2 Charging Port Replacement
  1. Toshiba Chromebook 2 Charging Port Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove all external devices from the Toshiba Chromebook 2.
  2. Toshiba Chromebook 2 Charging Port Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Close the Toshiba Chromebook 2 and turn it over so that the bottom of the laptop is facing upwards toward you with the lettering on the bottom facing right side up.
  3. Toshiba Chromebook 2 Charging Port Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Chromebook 2 Charging Port Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 8 visible Phillips 8.25 mm screws using the Phillips #0 screwdriver.
  4. Toshiba Chromebook 2 Charging Port Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Chromebook 2 Charging Port Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove 2 hidden Phillips 8.25 mm screws located underneath the rubber grips at the back (opposite the hinges) with the Phillips #0 screwdriver.
    • The rubber grips are glued in place, so you'll need to peel them up with a spudger or other pry tool.
  5. Toshiba Chromebook 2 Charging Port Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the back panel by pulling up on 2 adjacent corners.
  6. Toshiba Chromebook 2 Charging Port Replacement, Charging Port: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The changing port is located on the left side of the computer, when flipped over and the back cover is taken off, the port will be in the top right corner.
    • In order to access the port, the metal hinge in the top right corner must be lifted up.
  7. Toshiba Chromebook 2 Charging Port Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Chromebook 2 Charging Port Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Chromebook 2 Charging Port Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry the metal hinge up with the spudger tool by sticking the flat end under the bottom of the hinge and leverage it up.
    • Open the hinge all the way until it is sticking straight up.
  8. Toshiba Chromebook 2 Charging Port Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Chromebook 2 Charging Port Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Press down on the white clip with the pointed side of the spudger tool and softly pull the wires out of the socket by pulling horizontally away from the clip to disconnect the charging port from the motherboard.
  9. Toshiba Chromebook 2 Charging Port Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the charging port out by pulling up on the cable that connects the port to the motherboard.
    what happens to this port that it needs replacing?
    michael tracey - crwdns2934203:0crwdne2934203:0
crwdns2935229:010crwdne2935229:0
Jason Lomsdalen
crwdns2935283:010/06/16crwdne2935283:0
392 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 10-4, Livingston Fall 2016 crwdns2935289:0Cal Poly, Team 10-4, Livingston Fall 2016crwdne2935289:0
CPSU-LIVINGSTON-F16S10G4
crwdns2935297:011crwdne2935297:0
ok… but what's the part for the charging port itself to replace??
Brian “Deminox” Preston - crwdns2934203:0crwdne2934203:0
The power port part # is either SIQDD0BUHAD000(shorter) or SIQDD0BUIAD000(longer) depending on which model you have.
Tim Nolte - crwdns2934203:0crwdne2934203:0
I removed the damaged port, but don't know which part to order. The third line on the tag is 150104 and all the parts I see when googling have different numbers. The SIQ number is the same.
RS from LA1 - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 3,303
