Toshiba Chromebook 2 Battery Replacement
  1. Toshiba Chromebook 2 Battery Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove all external devices from the Toshiba Chromebook 2.
  2. Toshiba Chromebook 2 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Close the Toshiba Chromebook 2 and turn it over so that the bottom of the laptop is facing upwards toward you with the lettering on the bottom facing right side up.
  3. Toshiba Chromebook 2 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Chromebook 2 Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 8 visible Phillips 8.25 mm screws using the Phillips #0 screwdriver.
  4. Toshiba Chromebook 2 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Chromebook 2 Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove 2 hidden Phillips 8.25 mm screws located underneath the rubber grips at the back (opposite the hinges) with the Phillips #0 screwdriver.
    • The rubber grips are glued in place, so you'll need to peel them up with a spudger or other pry tool.
  5. Toshiba Chromebook 2 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the back panel by pulling up on 2 adjacent corners.
  6. Toshiba Chromebook 2 Battery Replacement, Battery: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Chromebook 2 Battery Replacement, Battery: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 4 Phillips 2 mm screws holding the battery in place with the Phillips #0 screwdriver.
  7. Toshiba Chromebook 2 Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Chromebook 2 Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Press down on the white clip and softly pull the wires out of the port to disconnect battery from the motherboard.
  8. Toshiba Chromebook 2 Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery by gently pulling up on the bottom corners.
    Thank you for the step by step guide!
    yoena lopez - crwdns2934203:0crwdne2934203:0
crwdns2935229:050crwdne2935229:0
Foster Chaney
crwdns2935283:010/08/15crwdne2935283:0
762 crwdns2915208:0crwdne2915208:0
IUPUI, Team 1-3, Hagerty Fall 2015 crwdns2935289:0IUPUI, Team 1-3, Hagerty Fall 2015crwdne2935289:0
IUPUI-HAGERTY-F15S1G3
crwdns2947412:07crwdne2947412:0
does the cb30-b-103 battery also work with the cb30-b-104 series?
henrikahlberg94 - crwdns2934203:0crwdne2934203:0
I had four screws holding down battery.
When re-installing cover, don’t get confused. There are two holes under rubber feet on side CLOSEST TO HINGES. These do not accept the two screws - put them on side AWAY FROM HINGES.
Bill Brasier - crwdns2934203:0crwdne2934203:0
Good instructions, my chrome is back to normal again .
Alexander Slaven - crwdns2934203:0crwdne2934203:0
Many thanks but now there’s no curser! What do I do?
Chris in UK
Chris Tighe - crwdns2934203:0crwdne2934203:0
Thank you, easy to follow, works like a dream
steve smith - crwdns2934203:0crwdne2934203:0
No cursor here either. Did Chris in UK get an answer?
laurasan464 - crwdns2934203:0crwdne2934203:0
Great set of instructions. Somewhere over the last 8 years I lost two screws out of the bottom, but it all worked fine regardless.
Excited to see battery life return to normal.
Phillip Mills - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 29,040
