Toshiba Canvio Connect V73600-C Disassembly
  1. Toshiba Canvio Connect V73600-C Disassembly, Begin opening case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Canvio Connect V73600-C Disassembly, Begin opening case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • On the side of your hard drive casing, insert a spudger.
    • This can be tricky as the tolerances are quite tight.
    • I used a needle to make the gap big enough to insert a pick.
  2. Toshiba Canvio Connect V73600-C Disassembly, Continue opening: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide your spudger along the gap in the casing you made in the previous step, continuing to open the device.
  3. Toshiba Canvio Connect V73600-C Disassembly, Keep going: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the spudger around the corner of the casing to start opening the next side.
    • There may be a gap big enough to see the plastic clips holding the device together.
  4. Toshiba Canvio Connect V73600-C Disassembly, Prise the casing open: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once there is a big enough gap in the casing, gently prise the two parts away from each other, being sure not to break any clips.
    • This will reveal the hard drive in the casing.
  5. Toshiba Canvio Connect V73600-C Disassembly, Extract the hard drive: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Simply lift the drive out of the case.
    • There may be some friction due to the anti-shock rubber on the corners of the drive.
    • Gently pry with a plastic pry tool if required.
  6. Toshiba Canvio Connect V73600-C Disassembly, Realise the drive is not suitable for internal use: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Canvio Connect V73600-C Disassembly, Realise the drive is not suitable for internal use: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Canvio Connect V73600-C Disassembly, Realise the drive is not suitable for internal use: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • As the drive has a USB port soldered directly to its logic board, instead of a converter board in between, disassembling this device seems to be pointless unless the hard drive is being used for parts.
Joel Taylor
crwdns2935283:003/07/20crwdne2935283:0
1.346 crwdns2915208:0crwdne2915208:0
Australia crwdns2935289:0Australiacrwdne2935289:0
Community
crwdns2936753:07crwdne2936753:0 39
crwdns2936753:030crwdne2936753:0 220
crwdns2942667:0crwdne2942667:0 7,645
