Toshiba CB35-C3300 Chromebook 2 Speakers
  1. Toshiba CB35-C3300 Chromebook 2 Speakers, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba CB35-C3300 Chromebook 2 Speakers, Back Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 2 rubber foot pads from the bottom (opposite the hinge) with the small Plastic Opening tool.
  2. Toshiba CB35-C3300 Chromebook 2 Speakers: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba CB35-C3300 Chromebook 2 Speakers: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 10 7.1 mm screws using Phillips #1 screwdriver.
  3. Toshiba CB35-C3300 Chromebook 2 Speakers: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Loosen the back cover by using a plastic opening tool all the way around the device.
    • There are areas all along the sides of the device that help aid in this.
    • Be careful when prying, and go slow. The silver plastic frame around the dull gray plastic bottom is fragile and easily dented from prying pressure.
  4. Toshiba CB35-C3300 Chromebook 2 Speakers: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba CB35-C3300 Chromebook 2 Speakers: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the back cover by gently lifting up on one side of the device.
    • The easiest side to lift up on is the one with the removed rubber foot pads.
  5. Toshiba CB35-C3300 Chromebook 2 Speakers, Battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba CB35-C3300 Chromebook 2 Speakers, Battery: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the tape holding the speaker wire to the battery on both sides using a small opening tool.
  6. Toshiba CB35-C3300 Chromebook 2 Speakers: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba CB35-C3300 Chromebook 2 Speakers: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 4 Phillips 3.2 mm screws holding the battery in place, with the Phillips #1 screwdriver.
  7. Toshiba CB35-C3300 Chromebook 2 Speakers: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba CB35-C3300 Chromebook 2 Speakers: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba CB35-C3300 Chromebook 2 Speakers: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To disconnect the wire from the mother board, gently press down with the flat end of Spudger and pull on the wire.
    • Gently shaking the wire from left to right helps with the wire removal
  8. Toshiba CB35-C3300 Chromebook 2 Speakers: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba CB35-C3300 Chromebook 2 Speakers: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the battery by gently pulling on the bottom corners.
    • Be careful to move the battery's wire under the speaker's wire.
  9. Toshiba CB35-C3300 Chromebook 2 Speakers, Speakers: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba CB35-C3300 Chromebook 2 Speakers, Speakers: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 4 Phillip 6.3 mm screws from both the right and left speakers using Phllips 1 screwdriver.
  10. Toshiba CB35-C3300 Chromebook 2 Speakers: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently remove wire from the motherboard by pulling it out of the connector socket.
  11. Toshiba CB35-C3300 Chromebook 2 Speakers: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba CB35-C3300 Chromebook 2 Speakers: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba CB35-C3300 Chromebook 2 Speakers: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the right and left speaker by lifting them up.
Mehdi Mohammadi
crwdns2935283:010/18/17crwdne2935283:0
416 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S1-G121, Cagle Fall 2017 crwdns2935289:0USF Tampa, Team S1-G121, Cagle Fall 2017crwdne2935289:0
USFT-CAGLE-F17S1G121
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 227
