Toshiba CB35-C3300 Chromebook 2 Motherboard Replacement
  1. Toshiba CB35-C3300 Chromebook 2 Motherboard  Replacement, WLAN Wi-Fi PCB: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two rubber tabs near the front of the computer with a metal spudger and with PH0 Phillips head screwdriver, carefully remove all ten screws and place in a safe location.
  2. Toshiba CB35-C3300 Chromebook 2 Motherboard  Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Ensure that there is no debris, dust, or any other foreign materials blocking the Wi-Fi PCB.
  3. Toshiba CB35-C3300 Chromebook 2 Motherboard  Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully peel back the yellow tape by either folding it back or removing it entirely. Use the same PH0 Phillips head screwdriver to remove the single screw that connects the motherboard to the Wi-Fi PCB.
  4. Toshiba CB35-C3300 Chromebook 2 Motherboard  Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • When the screw has been removed, the board will naturally spring up. Carefully apply light pressure to back the PCB out of its port.
  5. Toshiba CB35-C3300 Chromebook 2 Motherboard  Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the black wire that is plugged onto the 1 or AUX terminal by simply lightly pulling it from the board.
  6. Toshiba CB35-C3300 Chromebook 2 Motherboard  Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the white wire from the 2 or Main plug by lightly pulling it from the PCB.
  7. Toshiba CB35-C3300 Chromebook 2 Motherboard  Replacement, Motherboard: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use metal spudger tool to release the lever that holds the data cable to the board.
  8. Toshiba CB35-C3300 Chromebook 2 Motherboard  Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the speaker wire by gently pulling it out of the port.
  9. Toshiba CB35-C3300 Chromebook 2 Motherboard  Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove all three cables with a spudger that were hidden by the battery.
  10. Toshiba CB35-C3300 Chromebook 2 Motherboard  Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba CB35-C3300 Chromebook 2 Motherboard  Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove motherboard from within the laptop.
Ongela Helm
crwdns2935283:011/26/18crwdne2935283:0
109 crwdns2915208:0crwdne2915208:0
IUPUI, Team S6-G6, Wilson Fall 2018 crwdns2935289:0IUPUI, Team S6-G6, Wilson Fall 2018crwdne2935289:0
IUPUI-WILSON-F18S6G6
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 350
