This guide will not take long accomplish however it is crucial to remove the battery before removing any other part from inside the machine to help ensure no injury from electric shock.
Remove the 2 rubber foot pads from the bottom (opposite the hinge) with the small Plastic Opening tool.
Remove the 10 7.1 mm screws using Phillips #1 screwdriver.
Loosen the back cover by using a plastic opening tool all the way around the device.
I have the UK model and I found Fascinating Captain’s method for removing the back cover to be simplicity itself:
Remove the back cover by gently lifting up on one side of the device.
Remove the tape holding the speaker wire to the battery on both sides using a small opening tool.
Remove the 4 Phillips 3.2 mm screws holding the battery in place, with the Phillips #1 screwdriver.
To disconnect the wire from the mother board, gently press down with the flat end of Spudger and pull on the wire.
Remove the battery by gently pulling on the bottom corners.
Thank you AGAIN for your perfect HOW-TO Guide on Toshiba Battery Replacement!! Can you help me find a Replacement Keyboard for an ASUS Model W203A? I cannot even find a SINGLE ARTICLE on the Internet on this Model (no reviews, Asus, nothing). Thanks . Guy Rogers Attorney Jackson MS 601.941.6689
Thanks again IFIXIT!!! Repaced battery on Toshiba C35 C3300 with your HELP. Guy Rogers
