Toshiba A1304T Camera Replacement
  1. Toshiba A1304T Camera Replacement, Back panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a thumb-tack, push-pin, or similar pin, remove the four plastic stoppers located on the back panel.
  2. Toshiba A1304T Camera Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With the T8 Torx Security Bit Screwdriver, remove the four screws in the designated locations.
    • The T8 Torx Security Bit Screwdriver can be substituted with a small flathead screwdriver. Screw removal may be slightly more difficult however.
  3. Toshiba A1304T Camera Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba A1304T Camera Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • If needed, use the flathead screwdriver to gently pry the panel from the phone.
    • Using your fingers, lift the panel from the device.
  4. Toshiba A1304T Camera Replacement, Camera: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba A1304T Camera Replacement, Camera: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a small Phillips screwdriver, remove the two black screws from the positions indicated.
    • Gently pull the silver plate from the phone using your fingers.
  5. Toshiba A1304T Camera Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba A1304T Camera Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba A1304T Camera Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the head of a flathead screwdriver, flip the white segment of the socket that the camera's ribbon-wire runs into so that it is orientated vertically.
    • Gently lift the camera from its cavity and pull it away from the socket using your thumb and forefinger.
Christopher
crwdns2935283:004/22/10crwdne2935283:0
90 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 16-6, Maness Spring 2010 crwdns2935289:0Cal Poly, Team 16-6, Maness Spring 2010crwdne2935289:0
CPSU-MANESS-S10S16G6
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 2,095
