This guide requires removing the battery, casing, and rear wheels. Desoldering skills are required for replacing the motor. For reference, a desoldering guide is located here.
From the top view, remove each of the four pins that hold the casing in place.
Slowly pull the casing up to remove it.
Beginning at the bottom of the truck, twist the release clip on the casing until the release clip is no longer covering the battery casing.
Next, use a Phillips 00 screwdriver to remove the 8mm screw on the battery casing and remove the battery casing.
Finally, remove the battery from the white connector by squeezing the clip on the connector while pulling.
Using a Phillips 1 screwdriver, completely unscrew the 8mm screw located in the center of the wheel. Repeat this step for other wheels if needed.
Carefully pull the wheel off of its axle. Repeat for other wheels as necessary.
After removing the rear wheels, use a Phillips #1 screwdriver to remove the two 11m screws indicated.
Remove the metal piece that clasps the motor in place.
Carefully pull out the motor from the chassis.
Desolder the red and black wires from the motor. Note where each wire is supposed to connect.
My favorite trucks were Chalkboard Chuck and Samson, but I took pictures of several of the trucks and tried repeatedly to snap the perfect picture. {Obviously my perfect pics are a bit fuzzy.}
In addition to the big-honking Monster Trucks we also got to see some daring and dangerous motorcycle stunts!
