This guide requires removing the casing and front wheels.
From the top view, remove each of the four pins that hold the casing in place.
Slowly pull the casing up to remove it.
Using a Phillips 1 screwdriver, completely unscrew the 8mm screw located in the center of the wheel. Repeat this step for other wheels if needed.
Carefully pull the wheel off of its axle. Repeat for other wheels as necessary.
Pull the top half of the suspension to unclip it.
Remove the top clip along with the spring.
Pull up the bottom half of the suspension to unclip it.
crwdns2917034:0crwdne2917034:0
Hola buenas noches, me pueden hacer el favor de ayudarme a armar de nuevo la parte de la suspensión de la parte delantera, te go todas las piezas pero no recuerdo como van
