Toro Log Splitters 22618HD 2019 Cylinder and Wedge Assembly Replacement
  1. Toro Log Splitters 22618HD 2019 Cylinder and Wedge Assembly Replacement, Start the motor: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toro Log Splitters 22618HD 2019 Cylinder and Wedge Assembly Replacement, Start the motor: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the red engine ON/OFF switch to the ON position.
  2. Toro Log Splitters 22618HD 2019 Cylinder and Wedge Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toro Log Splitters 22618HD 2019 Cylinder and Wedge Assembly Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Follow the device's detailed operating and safety procedures before starting the device.
    • Pull the motor's pull-start cable to start the motor.
  3. Toro Log Splitters 22618HD 2019 Cylinder and Wedge Assembly Replacement, Extend the cutting wedge: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toro Log Splitters 22618HD 2019 Cylinder and Wedge Assembly Replacement, Extend the cutting wedge: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push the control valve lever towards the rear of the device to extend the piston and advance the cutting wedge.
  4. Toro Log Splitters 22618HD 2019 Cylinder and Wedge Assembly Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toro Log Splitters 22618HD 2019 Cylinder and Wedge Assembly Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the red engine ON/OFF switch to the OFF position.
  5. Toro Log Splitters 22618HD 2019 Cylinder and Wedge Assembly Replacement, Remove the slide bars: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toro Log Splitters 22618HD 2019 Cylinder and Wedge Assembly Replacement, Remove the slide bars: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an impact wrench with a 3/4 inch socket to loosen the twelve bolts and twelve nuts securing the slide bars to the underside of the cutting wedge.
    • If an impact wrench struggles to remove these bolts, a breaker bar may be necessary.
  6. Toro Log Splitters 22618HD 2019 Cylinder and Wedge Assembly Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toro Log Splitters 22618HD 2019 Cylinder and Wedge Assembly Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toro Log Splitters 22618HD 2019 Cylinder and Wedge Assembly Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the left slide bar.
  7. Toro Log Splitters 22618HD 2019 Cylinder and Wedge Assembly Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toro Log Splitters 22618HD 2019 Cylinder and Wedge Assembly Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toro Log Splitters 22618HD 2019 Cylinder and Wedge Assembly Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the right slide bar.
  8. Toro Log Splitters 22618HD 2019 Cylinder and Wedge Assembly Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove all twelve 3/4 inch bolts from the cutting wedge.
  9. Toro Log Splitters 22618HD 2019 Cylinder and Wedge Assembly Replacement, Restart the motor: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toro Log Splitters 22618HD 2019 Cylinder and Wedge Assembly Replacement, Restart the motor: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toro Log Splitters 22618HD 2019 Cylinder and Wedge Assembly Replacement, Restart the motor: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
  10. Toro Log Splitters 22618HD 2019 Cylinder and Wedge Assembly Replacement, Retract the cutting wedge: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the control valve lever to retract the cutting wedge until it is seated underneath the dislodger bracket.
    • Retracting the cutting head reduces the amount of hydraulic fluid inside the cylinder, resulting in less spillage.
  11. Toro Log Splitters 22618HD 2019 Cylinder and Wedge Assembly Replacement, Prepare for spills: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Residual hydraulic fluid will be trapped in the hoses connected to the cylinder, and will drip out during the following procedure.
    • Place a bucket underneath the device, below the cylinder to catch any hydraulic fluid drips.
    • Have rags handy to stop drips and clean up affected areas.
  12. Toro Log Splitters 22618HD 2019 Cylinder and Wedge Assembly Replacement, Remove the hydraulic connections: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toro Log Splitters 22618HD 2019 Cylinder and Wedge Assembly Replacement, Remove the hydraulic connections: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an adjustable wrench to loosen the nut securing the piston extension hose to the L-fitting on the side of the cylinder.
  13. Toro Log Splitters 22618HD 2019 Cylinder and Wedge Assembly Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toro Log Splitters 22618HD 2019 Cylinder and Wedge Assembly Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toro Log Splitters 22618HD 2019 Cylinder and Wedge Assembly Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the piston extension hose from the L-fitting.
    • This hose will have excess hydraulic fluid, so tilt it down towards the catch bucket and let the fluid drain out.
  14. Toro Log Splitters 22618HD 2019 Cylinder and Wedge Assembly Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toro Log Splitters 22618HD 2019 Cylinder and Wedge Assembly Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toro Log Splitters 22618HD 2019 Cylinder and Wedge Assembly Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use an adjustable wrench to loosen the nut securing the L-fitting to the side of the cylinder.
  15. Toro Log Splitters 22618HD 2019 Cylinder and Wedge Assembly Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toro Log Splitters 22618HD 2019 Cylinder and Wedge Assembly Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an adjustable wrench on the L-fitting itself to rotate it to a vertical position with the opening facing down.
    • This allows excess hydraulic fluid to drip out. Keep a bucket underneath the device to catch drips.
  16. Toro Log Splitters 22618HD 2019 Cylinder and Wedge Assembly Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toro Log Splitters 22618HD 2019 Cylinder and Wedge Assembly Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an adjustable wrench to loosen the nut securing the control valve to the fitting on the cylinder.
  17. Toro Log Splitters 22618HD 2019 Cylinder and Wedge Assembly Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toro Log Splitters 22618HD 2019 Cylinder and Wedge Assembly Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an adjustable wrench to loosen the fitting on the cylinder.
  18. Toro Log Splitters 22618HD 2019 Cylinder and Wedge Assembly Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toro Log Splitters 22618HD 2019 Cylinder and Wedge Assembly Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toro Log Splitters 22618HD 2019 Cylinder and Wedge Assembly Replacement: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slightly bend the control valve assembly away from the device to create a gap large enough for the fitting to clear.
    • Remove the fitting.
  19. Toro Log Splitters 22618HD 2019 Cylinder and Wedge Assembly Replacement, Shim the cylinder: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Shim the cylinder with wood blocks to keep it at its resting height, parallel to the frame.
  20. Toro Log Splitters 22618HD 2019 Cylinder and Wedge Assembly Replacement, Remove the pivot pin: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toro Log Splitters 22618HD 2019 Cylinder and Wedge Assembly Replacement, Remove the pivot pin: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toro Log Splitters 22618HD 2019 Cylinder and Wedge Assembly Replacement, Remove the pivot pin: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull to remove the two cotter pins securing the large pivot pin.
  21. Toro Log Splitters 22618HD 2019 Cylinder and Wedge Assembly Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toro Log Splitters 22618HD 2019 Cylinder and Wedge Assembly Replacement: crwdns2935265:021crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toro Log Splitters 22618HD 2019 Cylinder and Wedge Assembly Replacement: crwdns2935265:021crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the pivot pin.
    • The cylinder should now be resting on the wood shims.
  22. Toro Log Splitters 22618HD 2019 Cylinder and Wedge Assembly Replacement, Shift and rotate the cylinder and wedge assembly: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toro Log Splitters 22618HD 2019 Cylinder and Wedge Assembly Replacement, Shift and rotate the cylinder and wedge assembly: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The following steps require two people.
    • The cylinder and wedge assembly is extremely heavy, so use caution.
    • Shift the cylinder and wedge assembly towards the rear of the device, until it clears the central pin hole.
  23. Toro Log Splitters 22618HD 2019 Cylinder and Wedge Assembly Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toro Log Splitters 22618HD 2019 Cylinder and Wedge Assembly Replacement: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rotate the cylinder until the L-fitting is vertical.
  24. Toro Log Splitters 22618HD 2019 Cylinder and Wedge Assembly Replacement, Remove the cylinder and wedge assembly: crwdns2935265:024crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toro Log Splitters 22618HD 2019 Cylinder and Wedge Assembly Replacement, Remove the cylinder and wedge assembly: crwdns2935265:024crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toro Log Splitters 22618HD 2019 Cylinder and Wedge Assembly Replacement, Remove the cylinder and wedge assembly: crwdns2935265:024crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Support the cylinder and push the assembly towards the rear of the device until it clears the dislodger bracket.
  25. Toro Log Splitters 22618HD 2019 Cylinder and Wedge Assembly Replacement: crwdns2935265:025crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toro Log Splitters 22618HD 2019 Cylinder and Wedge Assembly Replacement: crwdns2935265:025crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the cylinder and wedge assembly.
For the amount of hydraulic fluid lost during this procedure, refill the hydraulic fluid tank.
Carsten Frauenheim
146,440 crwdns2915208:0crwdne2915208:0
crwdns2935297:0424crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,995crwdne2935297:0
crwdns2942667:0crwdne2942667:0 1,392
