Toro Log Splitters 22618HD 2019 Control Valve Replacement
  1. Toro Log Splitters 22618HD 2019 Control Valve Replacement, Disconnect the spark plug wire: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toro Log Splitters 22618HD 2019 Control Valve Replacement, Disconnect the spark plug wire: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before you begin, ensure that the engine is powered down and cool to the touch.
    • Grab the plastic housing at the end of the spark plug wire and pull firmly to disconnect it.
  2. Toro Log Splitters 22618HD 2019 Control Valve Replacement, Flip the engine switch to the off position: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toro Log Splitters 22618HD 2019 Control Valve Replacement, Flip the engine switch to the off position: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the red engine ON/OFF switch to the OFF position.
  3. Toro Log Splitters 22618HD 2019 Control Valve Replacement, Close the fuel valve: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toro Log Splitters 22618HD 2019 Control Valve Replacement, Close the fuel valve: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the fuel valve lever to the OFF position.
  4. Toro Log Splitters 22618HD 2019 Control Valve Replacement, Remove the control valve bracket bolts: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 3/8 inch socket to remove the three bolts securing the control valve to the control valve bracket.
  5. Toro Log Splitters 22618HD 2019 Control Valve Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 9/16 inch socket to remove the two bolts securing the control valve bracket to the frame.
  6. Toro Log Splitters 22618HD 2019 Control Valve Replacement, Remove the control valve bracket: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toro Log Splitters 22618HD 2019 Control Valve Replacement, Remove the control valve bracket: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the control valve bracket.
  7. Toro Log Splitters 22618HD 2019 Control Valve Replacement, Prepare for fluid drips: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Residual hydraulic fluid will be trapped in the hoses connected to the control valve, and may drip during the following procedure.
    • Place a bucket underneath the device, below the control valve to catch any hydraulic fluid drips.
    • Have rags handy to stop drips and clean up affected areas.
  8. Toro Log Splitters 22618HD 2019 Control Valve Replacement, Remove the output hose: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toro Log Splitters 22618HD 2019 Control Valve Replacement, Remove the output hose: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an adjustable wrench to loosen the nut securing the output hose to the L-fitting on top of the control valve.
  9. Toro Log Splitters 22618HD 2019 Control Valve Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toro Log Splitters 22618HD 2019 Control Valve Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the output hose from the top L-fitting.
  10. Toro Log Splitters 22618HD 2019 Control Valve Replacement, Remove the input hose: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toro Log Splitters 22618HD 2019 Control Valve Replacement, Remove the input hose: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an adjustable wrench to loosen the nut holding the input hose to the L-fitting on the bottom of the control valve.
  11. Toro Log Splitters 22618HD 2019 Control Valve Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toro Log Splitters 22618HD 2019 Control Valve Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the input hose from the bottom L-fitting.
  12. Toro Log Splitters 22618HD 2019 Control Valve Replacement, Remove the top L-fitting: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use an adjustable wrench to loosen the nut securing the top L-fitting to the control valve.
  13. Toro Log Splitters 22618HD 2019 Control Valve Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toro Log Splitters 22618HD 2019 Control Valve Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toro Log Splitters 22618HD 2019 Control Valve Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Spin the top L-fitting counter-clockwise to remove it.
    • This fitting is part number 340-16.
  14. Toro Log Splitters 22618HD 2019 Control Valve Replacement, Remove the bottom L-fitting: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use an adjustable wrench to loosen the nut securing the bottom L-fitting to the control valve.
  15. Toro Log Splitters 22618HD 2019 Control Valve Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toro Log Splitters 22618HD 2019 Control Valve Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toro Log Splitters 22618HD 2019 Control Valve Replacement: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the bottom L-fitting.
  16. Toro Log Splitters 22618HD 2019 Control Valve Replacement, Remove the piston extension hose: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use an adjustable wrench to loosen the nut securing the piston extension hose to the L-fitting on the rear of the control valve.
  17. Toro Log Splitters 22618HD 2019 Control Valve Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toro Log Splitters 22618HD 2019 Control Valve Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the piston extension hose from the rear L-fitting.
  18. Toro Log Splitters 22618HD 2019 Control Valve Replacement, Remove the control valve: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use an adjustable wrench to loosen the nut securing the control valve to the cylinder.
    • This connection is the last part holding the control valve to the device, so keep the control valve supported during removal.
  19. Toro Log Splitters 22618HD 2019 Control Valve Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toro Log Splitters 22618HD 2019 Control Valve Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the control valve.
  20. Toro Log Splitters 22618HD 2019 Control Valve Replacement, Remove leftover fittings: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use an adjustable wrench to loosen the nut securing the piston contraction fitting to the control valve.
  21. Toro Log Splitters 22618HD 2019 Control Valve Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toro Log Splitters 22618HD 2019 Control Valve Replacement: crwdns2935265:021crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toro Log Splitters 22618HD 2019 Control Valve Replacement: crwdns2935265:021crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Spin the piston contraction fitting counter-clockwise to remove it.
    • This fitting is part number 100-7671.
  22. Toro Log Splitters 22618HD 2019 Control Valve Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use an adjustable wrench to loosen the nut securing the L-fitting to the rear of the control valve.
  23. Toro Log Splitters 22618HD 2019 Control Valve Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toro Log Splitters 22618HD 2019 Control Valve Replacement: crwdns2935265:023crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toro Log Splitters 22618HD 2019 Control Valve Replacement: crwdns2935265:023crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Spin the L-fitting counter-clockwise to remove it.
    • This fitting is part number 340-98.
  24. Toro Log Splitters 22618HD 2019 Control Valve Replacement: crwdns2935265:024crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Only the control valve remains.
Carsten Frauenheim
152,089 crwdns2915208:0crwdne2915208:0
crwdns2935297:0439crwdne2935297:0
Staff
crwdns2935297:023,269crwdne2935297:0
crwdns2936753:030crwdne2936753:0 37
crwdns2942667:0crwdne2942667:0 1,156
