Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement
  1. Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement, Safety precautions: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement, Safety precautions: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before you begin, press the engine-stop switch to turn off the engine.
  2. Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unlatch the three rubber straps securing the cowl.
  3. Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Swing the cowl up until it rests securely on the frame.
  4. Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the fuel cutoff lever to the left to cut the fuel supply to the engine.
  5. Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  6. Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement, Remove the tub: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement, Remove the tub: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull up on the brake lever to disengage the brake.
  7. Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Rotate the tub until the yoke and dish assembly sit directly below the tub.
  8. Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push down on the brake lever to re-engage the brake.
    • Make sure that the brake is fully engaged.
  9. Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a 3/4 inch socket to remove the six nuts securing the tub to the dish.
  10. Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the six drum clamp plates from the tub mounting points.
  11. Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the tub up slightly by the gear ring to loosen the tub from the dish.
  12. Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The tub is extremely heavy and requires at least two people to lift it. Be sure to practice safe lifting techniques.
    • Lift the tub straight up from the dish and remove it from the device.
  13. Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement, Remove the dish: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement, Remove the dish: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a large crescent wrench to remove the bolt securing the dish to the bottom of the yoke.
  14. Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 3/4 inch socket to remove the lock bolt from the yoke.
  15. Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The dish is extremely heavy and requires at least two people to lift it. Be sure to practice safe lifting techniques.
    • Lift the dish straight up and remove it from the yoke.
    • A convenient place to set the dish is on top of the removed tub.
  16. Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement, Reassembly tip: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement, Reassembly tip: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • During reassembly, be sure to align the shaft indent with the lock bolt hole as you set the dish in place. Otherwise, you will not be able to properly lock the shaft and tighten the dish bolt.
  17. Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement, Remove the spindle: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement, Remove the spindle: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement, Remove the spindle: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a pipe wrench or an extra-large crescent wrench to loosen the dish plug.
    • Remove the dish plug.
  18. Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The spindle and bearings are very greasy. Handle these components carefully to avoid getting grease everywhere.
    • Push the spindle from the bottom of the dish.
  19. Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the spindle from the top of the dish and remove it.
    • After you reassemble the device, make sure to follow manufacturer instructions on how to properly lubricate the device with a grease gun.
  20. Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement, Remove the spindle bearings: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement, Remove the spindle bearings: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull and remove the bottom spindle bearing from the bottom of the dish.
  21. Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the top spindle bearing straight off the spindle and remove it.
Arthur Shi
crwdns2935283:001/03/18crwdne2935283:0
298,870 crwdns2915208:0crwdne2915208:0
crwdns2935297:0684crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,981crwdne2935297:0
crwdns2936753:030crwdne2936753:0 36
crwdns2942667:0crwdne2942667:0 1,377
