Toro Cement Mixer 68009HD 2018 Pulley Replacement
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. Toro Cement Mixer 68009HD 2018 Pulley Replacement, Safety precautions: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toro Cement Mixer 68009HD 2018 Pulley Replacement, Safety precautions: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before you begin, press the engine-stop switch to turn off the engine.
  2. Toro Cement Mixer 68009HD 2018 Pulley Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toro Cement Mixer 68009HD 2018 Pulley Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toro Cement Mixer 68009HD 2018 Pulley Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unlatch the three rubber straps securing the cowl.
  3. Toro Cement Mixer 68009HD 2018 Pulley Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toro Cement Mixer 68009HD 2018 Pulley Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toro Cement Mixer 68009HD 2018 Pulley Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Swing the cowl up until it rests securely on the frame.
  4. Toro Cement Mixer 68009HD 2018 Pulley Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toro Cement Mixer 68009HD 2018 Pulley Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the fuel cutoff lever to the left to cut the fuel supply to the engine.
  5. Toro Cement Mixer 68009HD 2018 Pulley Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toro Cement Mixer 68009HD 2018 Pulley Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  6. Toro Cement Mixer 68009HD 2018 Pulley Replacement, Remove the engine plate: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toro Cement Mixer 68009HD 2018 Pulley Replacement, Remove the engine plate: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four fasteners securing the engine plate:
    • Two 14 mm bolts
    • Two 3/4 inch nuts
  7. Toro Cement Mixer 68009HD 2018 Pulley Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toro Cement Mixer 68009HD 2018 Pulley Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toro Cement Mixer 68009HD 2018 Pulley Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the engine plate up and out of the device to remove it.
  8. Toro Cement Mixer 68009HD 2018 Pulley Replacement, Remove the V-belts: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toro Cement Mixer 68009HD 2018 Pulley Replacement, Remove the V-belts: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a 3/4 inch wrench to loosen the four bolts securing the engine to the frame.
    • You don't need to fully remove these bolts—loosen them enough to create slack in order to remove and replace the belts.
  9. Toro Cement Mixer 68009HD 2018 Pulley Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toro Cement Mixer 68009HD 2018 Pulley Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toro Cement Mixer 68009HD 2018 Pulley Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If you are replacing the belts, you can choose to cut the old ones to remove them.
    • Slide the belts off from the pulleys and remove them.
    • If you have trouble sliding the belts off, further loosen the four engine bolts to create more slack.
  10. Toro Cement Mixer 68009HD 2018 Pulley Replacement, Remove the pulley: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toro Cement Mixer 68009HD 2018 Pulley Replacement, Remove the pulley: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a crescent wrench to loosen the two set screws on the pulley.
    • Reassembly tip: The pulley is keyed to install in only one position.
  11. Toro Cement Mixer 68009HD 2018 Pulley Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toro Cement Mixer 68009HD 2018 Pulley Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toro Cement Mixer 68009HD 2018 Pulley Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the pulley off the axle and remove it.
  12. Toro Cement Mixer 68009HD 2018 Pulley Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toro Cement Mixer 68009HD 2018 Pulley Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the key from the axle.
Arthur Shi
crwdns2935283:001/03/18crwdne2935283:0
296.850 crwdns2915208:0crwdne2915208:0
crwdns2935297:0682crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021.151crwdne2935297:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 17
