Spudger4.9
Flip the mouse over and peel off the stickers on the perimeter of the bottom of the mouse.
Use the Phillips #1 screwdriver to remove four 5 mm screws from the bottom of the mouse.
Use the Phillips #1 screwdriver to remove the two 9 mm screws from the bottom of the mouse.
Grab the top shell of the mouse and lift up to remove.
Touch your capacitor discharge tool to the capacitor leads on the board to release the stored energy. If leads are inaccessible, wait until you've removed the board from the mouse body.
Use a spudger to pry underneath the white plug and pop it out to disconnect the upper board from the lower board.
Remove the 5 mm round head screw holding the middle piece to the top piece.
The outermost shell will now separate from the middle structure.
