Toniebox Broken Ear Repair
  1. Toniebox Broken Ear Repair, Toniebox Opening Procedure: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toniebox Broken Ear Repair, Toniebox Opening Procedure: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Put the Toniebox on a flat surface (e.g. a desk or a workbench).
    • Apply some pressure and turn the Toniebox counterclockwise to unlock the two clips beneath the bottom plate.
    • You will hear a "klick" when the two clips unlock.
  2. Toniebox Broken Ear Repair: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the bottom plate.
  3. Toniebox Broken Ear Repair: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the Phillips #1 screw on the bottom of the Toniebox.
  4. Toniebox Broken Ear Repair: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the inner part out of the foam housing.
  5. Toniebox Broken Ear Repair, Removing the Battery Compartment: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toniebox Broken Ear Repair, Removing the Battery Compartment: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the inner-plastic part out of the body
    • Loosen the two screws on the battery compartment and then carefully remove the battery compartment.
  6. Toniebox Broken Ear Repair, Remove the defective button: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toniebox Broken Ear Repair, Remove the defective button: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toniebox Broken Ear Repair, Remove the defective button: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the ears from the Toniebox according to the basic instructions for the Toniebox Teardown. Be especially careful not to damage the connector on the PCB.
    • Gently pull the inner ears down and out. Do not pull on the cable!
    • Use a pair of tweezers to carefully pull the defective button and PCB out of the silicone ear. If the cable is not torn off, be careful not to damage it.
  7. Toniebox Broken Ear Repair, Desoldering the defective button: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toniebox Broken Ear Repair, Desoldering the defective button: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toniebox Broken Ear Repair, Desoldering the defective button: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Solder the defective button from the PCB. The best way to do this is to use a hot air gun/ soldering iron around 360 ° C
    • Remove the excess solder with desoldering braid.
  8. Toniebox Broken Ear Repair, Solder the new button: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use lead free solder to reattach the replacement button
  9. Toniebox Broken Ear Repair, Soldering the torn cable: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toniebox Broken Ear Repair, Soldering the torn cable: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toniebox Broken Ear Repair, Soldering the torn cable: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the remains of the torn strand from the solder pads with the soldering iron
    • Isolate approx. 3mm from each wire of the line
    • Tin each pad and solder them on the back of the PCB. One wire on each pad. Be careful that the wire has no contact with outer copper surfaces.
  10. Toniebox Broken Ear Repair, Installation of repaired button: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toniebox Broken Ear Repair, Installation of repaired button: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toniebox Broken Ear Repair, Installation of repaired button: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully put the circuit board back into the ear.
    • Lay the strand in the designated channels.
    • Push the inner ears back into the ear sleeve using the buttons.
crwdns2935229:014crwdne2935229:0
crwdns2934873:0crwdne2934873:0
de en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
twayne Markinson
crwdns2935283:002/20/21crwdne2935283:0
1,386 crwdns2915208:0crwdne2915208:0
crwdns2947412:016crwdne2947412:0
Bei unserer Box ist der Schalter samt Platine weg. Kann man das Kabel auch direkt am Schalter anlöten oder hat die Platine eine Funktion?
Kevin Flaig - crwdns2934203:0crwdne2934203:0
Hi,
die Platine hat keine elektrische Funktion. Sie dient nur mechanisch dazu den Taster zu stützen. Wenn du es schaffst den direkt anzulöten geht das auch, ich weiss allerdings nicht wie gut das Veralten beim drücken ist oder ob das wider kaputt geht. Hier habe Ich neue Platinen gesehen die man allerdings selbst noch etwas bearbeiten muss:
https://www.ebay-kleinanzeigen.de/s-anze...
twayne Markinson -
Hier gibt es auch neue Platinen:
http://www.ebay-kleinanzeigen.de/s-anzei...
Ansonsten hat die keine Funktion. Ihr könnt die Kabel auch an die Taster direkt löten.
twayne Markinson -
Moin
Bei uns sind die ohren durchgeknabert. Ich will nur die orhen erneuern wo kann man die kaufen?
Matthias Lehmann - crwdns2934203:0crwdne2934203:0
Ich kann gerne einige 3D-Drucken und sie verschicken.
Benoit74 -
crwdns2936751:024crwdne2936751:0 20
crwdns2936753:07crwdne2936753:0 156
crwdns2936753:030crwdne2936753:0 749
crwdns2942667:0crwdne2942667:0 81,763
