TomTom VIA 1530 TM Back Replacement
    1. TomTom VIA 1530 TM Back Replacement, Back: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 TomTom VIA 1530 TM Back Replacement, Back: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Position the device so that the underside is facing up.
      • Tilt the EasyPort Mount slightly upward and rotate it counterclockwise 180 degrees from the initial position.
      • Firmly grab the EasyPort Mount and remove it.
      • If it does not dislodge easily, gently twist the EasyPort Mount, applying increasing pressure until it does.
    2. TomTom VIA 1530 TM Back Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 TomTom VIA 1530 TM Back Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Turn the device 180 degrees so the screw in the EasyPort Mount compartment is on top.
      • Remove the 2mm screw beneath the EasyPort Mount compartment with the Torx T-5 head Screwdriver.
    3. TomTom VIA 1530 TM Back Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 TomTom VIA 1530 TM Back Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Flip the device over so that the screen is facing up.
      • Wedge the plastic opening tool between the top and bottom of the device's frame, gently sliding it around the outside edge.
      • It may be easier to start at one of the corners.
      • The gold ribbon cable connecting the screen to the motherboard is fragile and tears easily.
      • This specific device's ribbon cable is torn.
    4. TomTom VIA 1530 TM Back Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 TomTom VIA 1530 TM Back Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Carefully slide the screen forward, revealing the lower portion of the motherboard.
      • Remove the 3.6mm screw using the JIS #00 Screwdriver.
      • Rotate the device 180 degrees, carefully slide back the screen, and remove the remaining two screws.
    5. TomTom VIA 1530 TM Back Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 TomTom VIA 1530 TM Back Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 TomTom VIA 1530 TM Back Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Disconnect the battery and speaker cables.
      • Unlatch the motherboard from the case.
Jennifer Zakaria
crwdns2935283:001/18/18crwdne2935283:0
555 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S12-G2, Banghart Winter 2018 crwdns2935289:0Cal Poly, Team S12-G2, Banghart Winter 2018crwdne2935289:0
CPSU-BANGHART-W18S12G2
crwdns2942667:0crwdne2942667:0 981
